Hi, a few months ago I purchased Fatshark Attitude google with the transmitter Fatshark 5.8 Ghz 250 mW. I have used many times the transmitter without any problems, I connected it to the wrong voltage last time it burned a capacitor. Since I don’t know this capacitor and where I can buy it.
Could you please help me!
The original value was 47uF 25V but it can be replaced by any cap 10-100uF 25-50V. Even a DIP cap will work as its an input cap and not critical. TX should work even after the cap is removed to test it (but not a good idea to run a long time without the input cap).
You can buy them from farnell/mouser but they usualy have a minimum order, in which case you can have a look on ebay for a replacement
http://www.ebay.co.uk/itm/Tantalum-Capacitors-Solid-SMD-25volts-47uF-10-/201006747860?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item2eccef90d4
Hope that helps!
