I cant seem to remove/unplug the battery tray that is inside the DEVO 10 white transmitter. Can anyone else remove that plug or do you think it’s in there permanently?
I had to use a screwdriver to get it out. It is in there really tight. Used the driver to prize it out!
Yes sometimes its rather hard to remove but its definitely possible, just be careful when plugg it out not to pull to hard on the cable as the last thing you want is for one of the cables to pull out of the connector!
