When I upgrade my APM firmwire from V3.0.1 to V3.1 DO I have to re-caliberate all the sensor like accelerometer and compass? Or do I have to reinput my PID values and and the trim values which
I saved using save trim. ???
Depending on the firwamre upgrade it will sometimes require the settings to be overwritten. So before any upgrade I suggest you save your PID values and settings via the mission planner and then you can re-load them once the new firmware is on.
sorry but I dont know how to save them. Can I also save the accelerometer and compass calibration values???
Start up mission planner…
Once the settings have been read from the APM go to Config/Tuning → Full Parameter List
On the right hand side of the screen hit the Save button
That saves everything
thanks again Louise. does that saves the accelerometer calibration values also?
I think so but not 100% sure, have a look through the parameters and see if you can spot it
